whats the easiest way to empty gas tank?
KevinKay
I have a mercrusiser 3.0L GM 4 cylinder engine. i pulled the carb off and thought with the key turned it would operate the gas pump, but it only runs when the engine is cranking?? I want to empty the tank without pulling up the floor.
Thanks!
blifsey
Re: whats the easiest way to empty gas tank?
WOT :) :) :)
Never tried siphoning gas from tank but have read some boats have a valve type thing in place to keep a siphon hose from reaching tank.
arks
Good Ol'fashion siphon ?
Yeah, a siphon would be easiest if the boat is out of the water. If you have trouble getting a siphon tube down the fill then you'll have to get to the top of the tank. The boat should have an access port in the floor above the sending unit. Remove the sending unit and siphon from there. A couple years ago I siphoned 60 gallons out of my Silverton when she was hauled for the winter. It was easy after I figured out how to hold the suction end of the hose to the bottom of the tank.
You could also use a manual or 12V electric fuel pump (rated for GAS) and pull it out, which doesn't require the boat tank to be higher than the destination tank.:)
HAV2FISH
If you can get to your sending unit there's your entry point for your siphon tube. That is if you cant stick it down the fill tube.
Beefer
Turn it over! :D Sorry...
But seriously, fastest way would be to get a 12v fuel pump, and make an electrical siphon. You should be able to siphon through the fuel fill if you absolutely can't access the sending unit or the pick up.
The safest (IMO) is with a manual siphon pump. I picked one up at my local auto parts store for $12, and it took about an hour (maybe more) to siphon out 40+ gals.
If you can't access the sending unit or pick up, try tapping into a fuel line, maybe at the pump ball, and siphon from there.
smokeonthewater
well in my experience all I have to do is THINK about turning my ignition keys and there goes my gas.....
A cheap inline electric pump from your local auto parts store works well but remember safety.... Connect it to a battery that is outside the boat and away from any gas fumes...... Those pumps also work fairly well for changing your oil
bigbad 4cyl x2
attach a longer hose to the output which the fuel will come out of ,block off the fuel fill with a wet rag and pressurize the vent line with air from a compressor . fuel will come out
HT32BSX115
Howdy,
If you have never removed gas from that tank before, siphoning through the gage sender hole is probably best.
Use 3/4" clear hose and put a piece of PVC pipe on the end that goes in the tank.
Get enough hose so you don't have to use your mouth to get the siphon started. (you can pour gas into the hose to fill it first. then raise the filled hose to clear the bubble)
Also get a small PVC ball-valve with another piece of PVC pipe on the other end so your helper can shut off the flow and not lose the siphon while changing containers as they fill up. (so none is spilled)
With the short length of PVC pipe on the "tank-end" you can vacuum out any water or debris in the tank. (jack the bow up so the water will run to the back where the sender is)
DO THIS OUTSIDE away from the house (um.......NO SMOKING!!)
Regards,
Rick
paultjohnson
Just gimme the keys and a 12 pack
sbbamafan
Drive it like you stole it!!!!!
ChampionShip
How does a guy actually clean the tank to get all the debris and crap out after all of the gas is removed?? Hypathetically... :)
took off the fuel line threw the tank and waited till it dried about 30 or so min and vac it out got it all i had bad gas and dirt in there for two years and did not know
Doryboy
There's two ways to get that fuel, now that you have the carb off. You can hook the fuel line that went to the carb to the inlet side of an electric pump, and pump the fuel into a bunch of gas cans, or you can hook a long piece of hose up to the same line and siphon the fuel out. If you're going to siphon it, the boat should be out of the water. Otherwise, to get the output end of the siphon lower than the input you'll be underwater. And that's not very comfortable this time of year.
CHAWK46
paultjohnson's right. Air flowing through a plastic hose creates static electricity. That's why cabinate shops use metal pipes for their dust vac systems. Plastic can cause dust explosions.
Droopy
Can't believe no one has gotten this right yet...
Easiest (and fastest) way to empty gas tank?
:D
A match!
:eek:
John
(Disclaimer, probably not the safest way and the boat may not be reusable... But should be exciting!)
