mattsanders
Thread starter- Joined
- Sep 2, 2009
- 54
What does the oring at the top of the driveshaft do? Is is a requirement?
The o-ring is more or less a shock absorber for the spline that goes into the crankshaft and it helps keep the drive shaft centered in the crank shaft as well. Without it, the spline on the drive shaft will get beaten up more and create more damage to the inner crankshaft spline and driveshaft spline. Does this make sense to you.
If you should loose the one off of yours, you should be able to buy another one, easy enough. You could also go to the parts house and get a universal type, that matches the same dimensions as your original. The best way to check your dimensions is to measure the thickness of your old one with a dial caliper and get one that fits relatively tight over the end of the spline. I believe the diameter of the o-rings are about .048 to .062, depending on what motor you have. Some could go as high as .080
How often should this o-ring be checked ? I used marine grade bearing grease on the splines, is this the preferred method? -Thanks
