ttownthomas
Thread starter- Joined
- Jun 7, 2019
- 204
As I work through the mechanicals I decided to disassemble the uppers from my 1972 Bertram project. MC-1 165's. I watched some online videos and studied seloc and the fsm. My spanner came today so I took it apart. Got everything but the larger driveshaft seal apart. Here are the pictures. Not overly optimistic about it at this point.
Upper cap outer race:
MC-1 Upper - 1 by ttownthomas, on Flickr
Top driveshaft bearing:
MC-1 Upper - 2 by ttownthomas, on Flickr
Drive shaft Gear:
MC-1 Upper - 3 by ttownthomas, on Flickr
Output end of gear assembly:
MC-1 Upper - 4 by ttownthomas, on Flickr
Lower seal, the mangled part was just floating in there:
MC-1 Upper - 5 by ttownthomas, on Flickr
Yoke:
MC-1 Upper - 6 by ttownthomas, on Flickr
Yoke Seal:
MC-1 Upper - 7 by ttownthomas, on Flickr
Mounting surface for lower seal:
MC-1 Upper - 8 by ttownthomas, on Flickr
Gear assembly and roller bearing assembly. Looks like it has been hot.
MC-1 Upper - 9 by ttownthomas, on Flickr
Outer race of lowest roller bearing on driveshaft:
MC-1 Upper - 10 by ttownthomas, on Flickr
Roller bearing looks like it has been spinning due to discoloration?
MC-1 Upper - 11 by ttownthomas, on Flickr
MC-1 Upper - 1 by ttownthomas, on FlickrTop driveshaft bearing:
MC-1 Upper - 2 by ttownthomas, on FlickrDrive shaft Gear:
MC-1 Upper - 3 by ttownthomas, on FlickrOutput end of gear assembly:
MC-1 Upper - 4 by ttownthomas, on FlickrLower seal, the mangled part was just floating in there:
MC-1 Upper - 5 by ttownthomas, on FlickrYoke:
MC-1 Upper - 6 by ttownthomas, on FlickrYoke Seal:
MC-1 Upper - 7 by ttownthomas, on FlickrMounting surface for lower seal:
MC-1 Upper - 8 by ttownthomas, on FlickrGear assembly and roller bearing assembly. Looks like it has been hot.
MC-1 Upper - 9 by ttownthomas, on FlickrOuter race of lowest roller bearing on driveshaft:
MC-1 Upper - 10 by ttownthomas, on FlickrRoller bearing looks like it has been spinning due to discoloration?
