What's the worst outdrive you know of?
Rainmaker
Re: What's the worst outdrive you know of?
Actually it's OK to run a stringer with the drive "a little" up at idle speeds as long as the water squirter is squirting water on the ball gears. Using the tilt for trim is not smart.<br /><br />I am a former stringer victim myself. I agree that these are the bottom of the heap. But there are some good points:<br /><br />1). I actually liked the ball gear setup. Couldn't see any noticeable wear in 6 years (1800 hours) of use. And it was used when I got it. Have to keep that squirter squirting.<br /> <br />2). I think the electric shift aspect of the early stringers (pre-78) gets a bad rap. Never had a single problem with mine. Always shifted only at idle, always a nice, smooth, quiet shift. Very nice during docking manuevers.<br /><br />3). The turning radius of a stringer-equipped boat will always be less than the others. The drive pivots a full 90 degrees. All others are somewhat less.<br /><br />Now the bad: The worst part about these drives is the upper housing. There are too many penetrations (steering shaft, pivot points, dip stick) allowing too many potential leak points. For the top pivot point, there is only an O-ring sealing a rotating interface with a pressure diferential. This will leak.<br /><br />OMC sold a huge number of these things. So ebay will have used parts for a while to come.<br />mike
CharlesW
Originally posted by Rainmaker:<br />[QB] Actually it's OK to run a stringer with the drive "a little" up at idle speeds /QB]
I was told that when I purchased mine new in 1975. The problem with that was what is "a little" up, and how do you be sure to always put it back down when you are coming off idle speed. I just decided to never chance a wrong estimate or an uh, oh, forgot to put the drive down happening. The ease of shifting, the short turning radius, and the quietness of the drive was what made me decide to buy the OMC at the time. Never regretted it, possibly because I never knew it was supposed to be so bad.
Rainmaker
Charles,<br />I could definately hear a difference when the drive was up. Even the slightest amount. So I had an audible warning of a raised drive.<br /><br />I wish OMC had evolved the drive. The good points I mentioned were worth building on. But they didn't, I think because (at the time) they had significant market share. So they were unprepared when the competition decided to compete.<br /><br />Anyway, I had tons of fun with my stringer-equipped boat. But I really had to keep an eye on it, and baby it a certain amount.
D
DJ
Guest
Alex,<br /><br />Yep, that's sort of what I meant. ;) Everyones version of "noraml" is a bit different.<br /><br />I have actually seen them spit the gears right out the back when hammered. Granted, that was with a mildly hopped up engine.<br /><br />If you ham hand them with standard power, you're still "risking it".
