Whats this - 95 70hp Force
atengnr
Could someone tell me what this threaded stud is for? Thanks alot!
Jiggz
Doesn't show on the parts drawing. Is this on the gear shift cam? If it is, then maybe it's a mod made by the previous owner.
atengnr
Its the threaded stud, below the green loop of wire in the photo. The stud is on the shift bracket.
Jiggz
Here's a parts drawing for the gear bracket.
atengnr
Thanks. Well this would suggest that someone drilled a hole in the bracket and added a stud. Why on earth would this have been done?
jerryjerry05
Maybe they weren't getting the travel with the current setup?
Couldn't really see the pic you posted??
atengnr
Thanks. Heres another pic. Could someone also confirm that I have these cables set up correctly? I went out to the lake yesterday and cant seem to hold forward unless I push the shift bracket manually, as cable seemed to pull short of full travel to forward gear (albeit, the cable isnt connected to control box yet as waiting for a part, so was shifting end of cable "by hand"). Thanks alot.
jerryjerry05
Once it clicks into gear, it shouldn't come back out by itself??
Maybe the dogs worn? Linkage needs lubed?
If someone added a second post they might have had trouble staying or reaching the gear?
Half way up the shift rod, there's a connector.
It can be adjusted to help the shift rod make a longer push?
atengnr
Thanks. I lubed the linkage, and has new cables on it. It seems that it drops into gear if I shift the motor without the cable, at least when I check by rotating the propeller.
