Wheel Bearings
agallant80
I don't know anything about the bearing size of my trailer. Its a dual axle Venture. has 6 studs. Can anyone tell me bearing size based on that?
Wind dog
Re: Wheel Bearings
Some might, I can't. My advice is to tear them down & bring the bearings & seals with you when you go to the parts store.
WIMUSKY
Re: Wheel Bearings
Pull the hub apart. There will be a number on the bearing and a number on the seal.....
Thalasso
Re: Wheel Bearings
Cal these people. Have your vin number ready and they will tell you
Venture Trailers Incorporated | 5301 North Point Blvd| Baltimore, MD 21219 | 410.388.1000
ToemanDoug
Re: Wheel Bearings
If you want to take a gamble, try:
#25580 inner and # 15123 outer bearing.
Otherwise, what Thalasso said
four winns 214
Re: Wheel Bearings
Are buying new bearings as spares? Since your boat is new, it would be highly unlikely that you need to replace your wheel bearings at this point. They should only need routine maintenance- grease, etc. When I tow, I do what many on this forum have suggested and carry a ready-to-install complete hub assembly that includes grease packed bearings. That way if I have bearing problems on the trip, I simply change hubs. Much easier than changing bearings on the side of the road.
BrianNJ
Re: Wheel Bearings
From here. Venture
What size bearings are on my trailer?
1 1/16" x 1 3/8"- All 5 bolt hubs on trailers with brakes
1 1/4"x 1 3/4"- All 6 bolt hubs
bruceb58
Honorary Supreme Mariner
Re: Wheel Bearings
You also need to know the seal number as you always replace it when you change out the inner bearing.
Always change the races when you change the bearings.
agallant80
Re: Wheel Bearings
Hellow everyone.
Thank you so much for your responses.
Four Winns 214, yes they are extra. I had some wheel studs snap on me during my last trip and it got me thinking of what extra parts I should keep on hand.
Bruceb58, what do you mean by "races" is that the seal?
BrianNJ, my google ability must have been off yesterday. I spent some time on the venture website and seamed to have passed that section over. Thank you for digging it up.
Silvertip
Re: Wheel Bearings
A bearing has two parts. The tapered roller bearing assembly and the race which is also called a cup in which the bearimg rotates. The seal is a separate piece that installs at the back of the hub to prevent loss of grease. The race is press fit into the hub.
Thalasso
Re: Wheel Bearings
From here. Venture
Went on there site to find that. Knew it was there but couldn't find it
