Re: Wheel hub replacement issue
I replaced a wheel hub for the first time and I think I did it correctly but when I put the spindle nut on, it seems like it is going on to far. I am tightening it very tight and it almost goes all the way into the hub. The cotter pin is outside of the grooves on the spindle nut . Is this going to be a problem?
Did you mean to use the wording in red above instead? Is the above what your trying to say?
If yes, do you have the thick washer under the spindle nut?
Also, the spindle nut should not be installed "very tight".
Wrench it down good, kinda "very tight" and then back it off until the hub
freely spins around two or three times before coming to a stop.
