Howard Sterndrive
- Joined
- Nov 5, 2008
- 4,603
On this board, there seems to be a lot of threads where the poster says their i/o engine exhibits symptoms of needing a tuneup. e.g hard starting, rough idle, low power out of the hole, loss of top end speed
But then, in so many instances... they then say they want to "rebuild the engine" or have it rebuilt, to correct it...
I can't understand where that comes from. I can't find any reference here that says an engine rebuild would be the solution to ANY of those sorts of problems.
In my humble opinion.... you rebuild an engine for 1 of maybe 3 reasons:
1. Loss of oil pressure due to worn internal components (bearing issue)
2. Excessive blowby/loss of compression due to worn internal components (ring/cylinder wall issue)
3. catastrophic mechanical failure of internal components (e.g. spun bearing or failed piston)
and then, you can pare that all down to One common denominator:
Excessive Wear or Failure of Internal Components
If your engine does not have Excessive Wear or Failure of Internal Components then it does not need rebuilding.
What it needs is diagnosing of the systems such as fuel and ignition and a proper repair, adjustment or replacement of components external to the engine.
