1946Zephyr
- Joined
- Oct 21, 2008
- 5,556
Re: When to quit?
No, the reeds are fine. 80 PSI on an old QD like this, is decent. The compression is dead even with the two. So count the reeds out for being the problem.
If the carb is nice and clean inside, I highly doubt if this is the problem too.
Back to the ignition system:
Did you replace the spark plug leads when you rebuilt the ignition system? A lot of people will replace the coils without replacing the spark plug leads. Even if they do, often times the connection from the coil to the spark plug lead is not very good. The faces of the coils also have to be lined up with the machined face perfectly or you're spark will not be perfect. Those who run the old spark plug leads after changing the coils will often overlook the spark plug boot connections too.
I still think your issue may be in the ignition system.
