Where can I find rejet info?
John Lapic
I have a recent post regarding no power at WOT. I have taken my 71 Johnson 9.5 from 1300 ft to 6000 ft. and it will not open up. Two local dealers suggest changing prop pitch. Several of you suggest a rejet which I like as my first option. Problem is I have contacted every dealer in my area and none give me any recommendations for new jets. They can replace the one I have but I want one that will lean this out a bit. Does anyone have a source that I can use to suggest and supply different jets? I have done some web surfing and cannot find a source. I am sure someone out there can point me in the right direction.
wilde1j
Re: Where can I find rejet info?
Your motor may be too old, but I would try BRP customer service. BTW , were the dealer BRP dealers?
John Lapic
Two of the local dealers were BRP dealers, and they both pushed prop pitch change. I'll try BRP Customer service
ezeke
The lack of air is the problem, so the only fixed jet is the high speed at .049 part #309681, superseded to # 324020.
You need less fuel so try the smaller openings.
328542 = .047
328541 = .046
323380 = .045
328544 = .044
328539 = .043
Be sure to reset your lean rich idle adjustment,
