Where can I find these windshield brackets? (see pic)
BonairII
One of my windshield brackets on my '67 Glasspar Avalon is broken and I need to find a replacement(s). I don't care if the new brackets are exactly the same or are just generic.
Woodonglass
Re: Where can I find these windshield brackets? (see pic)
Boat Salvage, eBay, Craigslist etc... They are not mfg any longer.
BansheeVision
With out seeing more than just the close up pic, I'll suggest that if the broken off base piece is hollow and the part it came off is also hollow maybe you could slide a piece of box or channel metal inside them and drill holes to put in screws. maybe a dab of 2-part epoxy for good measure. If the voids are different dimensions you can fill in with sheet metal shims. This side would then be stronger than the other, and when that one broke you would have matching screws on each side.
