Where do I look to check impeller stream?
dubs283
Re: Where do I look to check impeller stream?
sterndrives do not "pee" like an outboard
if you need to check water flow, pull the supply hose at the t-stat housing and run briefly
otherwise, while running on muffs, check for water exiting through exhaust ports at the transom and feel the risers for "coolness"
cr2k
If it has been 2 years or more OR you don't know how long it's been it is time for a new impeller. Read my sig....
