Where do I look?
2kvert
Hi all. 96 4.3 lost power had water in oil. Gray milkshake.
compression check was 200 in all but cylinder 5 which is zero. Valve train looks ok
I just did rings and bearings etc last summer.
Pulled the head and found no obvious problem with gasket or head.
Thoughts?
Place a steel straight edge and feeler gauge and check for warpage across the head
2kvert
That's all I could think of too. Temp guage never read high this year, but I'm not sure how accurate it is.
ill try the straight edge and maybe run it to a machine shop to check it out further.
Thanks
Ayuh,...... Is one of the valves rusted open,..?? Zero is hard to get,....
The others are high from the water, 'n oil,....
Any value higher than 150 psi means you either have a bad gauge, or you have water or oil in your cylinders.
150 PSI is the published cranking PSI for a new motor
2kvert
That's good to know. I thought it was high but ince I had just re ringed it , I assumed I was just awesome
