Texasmark
- Joined
- Dec 20, 2005
- 14,977
I keep harping on this and it gets little attention. Personally I don't care that it doesn't. I know where to run mine and if you choose otherwise it's your equipment, your boat, your outing.
I live in N. Texas and several weeks ago we had a bad ice storm. Ice on the trees was something like a 1/4" branch was 3/4" in diameter due to the ice. Multiply that by the number of small branches and the big guys couldn't take it. Lots and lots of broken main branches.
I am still working over that pile of wood and will be for at least a couple of months but while cutting it all up for next year's fuel for my wood stove one thing came to mind:
My main cutting instrument is a nearly new 16" Stihl MS170 2 cycle chain saw. I have several unused new chains and adequate files and all to keep the chains I'm using, sharp. An added plug, I use full synthetic oil in it and it does-not-smoke, just like my OB engine on my boat.
Moving on. If I set the chain on a log with the engine idling, and then pull the trigger, the engine will lug and if I don't lift it off the log will die. Typical 2 cycle (2 stroke for you new comers) overload. Just like when you have too much prop or too much load in the stern, or too small an engine, or whatever that overloads your 2 cycle engine it just craps out........it can't take the stress.
However. If I hit the trigger a few times off the log.....rmmmm....rmmmmm.....rmmmmm, and then hold the trigger full on, running the engine up to max rpms, and then put the blade on the same log, it breezes through it, hardly loosing any rpms, wood chips going everywhere a few seconds later the cut portion falls off.
Same applies to your OB engine. Prop it to run at the upper end and it will do the same for you. Prop it for the lower end and you get what you deserve, puke for performance.
Mark
Mark
