pinecrestwoods
Thread starter- Joined
- Jun 17, 2009
- 100
I've got a '93 Ebbtide 182 (bowrider... see avatar) with 4.3 lx Alpha One, Gen II. I got it a couple months ago and am still learning. I can't find any pictures of the anatomy of the hull. I had to do all of the seals/bellows, and think I have all of the leaks stopped.
Now my issue is: There is some liquid (left-over oily water (green-ish)) that appears in my bilge, probably less than 1 qt. Not enough for my pump to totally remove. Then, when out of the water, and the boat is at rest, it "disappears"- I suppose into the lower part of the hull. I do have a screw-in plug at the back of my boat (lower than the bilge area). I park my boat at a bit of an incline, remove the plug, and MAYBE a tsp. comes out, if that. Where is this liquid going, can I get it out, and should I be concerned?
I have raised the bow up as high as I could with the tongue jack and tried to flush the back of the boat with dishsoap and water (had my plug out and ran the bilge pump). I think this improved my situation (less sludgy, anyway), but the amount of liquid stayed about the same.
I just don't know where the liquid can be hiding.
Thanks- hope it made some sense,
Jeff
Jeff
