Where does throttle body muffler go?
andrewterri
Where does the little square muffler go? Ordered it and matched part number from merc but I do not have one to replace. The diagram points to a oval hole for a square piece. I tried uploading a picture but can't. There is two oval slots and one looks like a piston slides through.
scoflaw
Ensign
It's where the IAC pulls it's air from, so will be in close proximity to that valve
andrewterri
Wholly crap Alldodge, after reading your Rinker post I think that black "piston" is really the muffler. I was looking for a center post or pin to put it on since the square muffler has a center drilled out to set on a post. If that is what im seeing this there a metal pin or post the foam "muffler" goes on?
achris
More fish than mountain goat
.... If that is what im seeing this there a metal pin or post the foam "muffler" goes on?
No, it just pushes into the cavity... Not sure what the hole in the centre is all about... :noidea:
Chris.......
andrewterri
Thank you Chris. I will get mine in there with hopes it does not get sucked through the intake :joyous:
