Where is a good place to buy parts?
gunterm
Might be hard because this is an old outboard, 1969 Chrysler 55hp. I need lower unit seals/gaskets because it leaks gear lube into the water and vice versa, and also was going to replace the water pump/impeller while I'm in there, does iBoats marine store have the right items?
gunterm
Re: Where is a good place to buy parts?
bump...
I don't want to accidentally buy something that won't fit, need lower unit gaskets to stop a leak and water intrusion and I'm not sure if I should just replace impeller or need a whole new water pump kit (preventative maintenence)
eurolarva
Seal kit for that motor is 26-820645A- 1. Cost is around $30 bucks. Mercury sells them. It is a quick silver number. The gasket between the two lower unit pieces is no longer available but can easily be made with gasket paper and non hardening permatex.
