Where is cooler drain for Sportsman Bluefin?
NMShooter
Hmmmm.
I loaded up the port side bow cooler on my 1988 17' Sportsman Bluefin. Noticed that there was a drain in the bottom, but for the life of me I can't tell where it drains to. Does this just drain into the hull and is subsequently drained out the stern plug?
Yuck if so.
NYBo
Re: Where is cooler drain for Sportsman Bluefin?
That's the way my boat is set up.
Yuck if so.
Ayuh,... You could plumb a dedicated thru-hull from it,.... I'd put it at, or above the waterline though....
DuckHunterJon
Mine also goes to the bilge, then out. Not sure why you say Yuck. It's just melting ice - the beer stays IN the cans.
Maclin
but DuckHunterJon, he did no say what HE loaded it up WITH.... :D
NMShooter
Yeah... that was the problem. I put some crappies covered in ice in there :)
