Where is exhaust shutter?
Status
Not open for further replies.
dara64
1982 merc 470 sterndrive (pre-alpha drive), I have searched my manual cant find any reference to it at all. I have the riser off,when I looked down the hole there is a bar running across the hole nothing attached to it.
My exhaust has been comming out the side holes and not out my center prop.Anyone know exactly where it is located? I know some older ones the motor needs to be removed to replace. If it has fallen down in the exhaust how do you go about removing it? I dont see anything down the tube looking in from the top.
Any info would be great
Thanks
cooter2506
Re: Where is exhaust shutter?
Remove your outdrive. Bet ya find it stuck in the bell housing end of the exhaust.
dara64
If it is stuck there what does this cause? I mean when the exhaust is partially blocked by something what type of symptoms.
Thanks
Dara
Ayuh,...
Possibly, down on power, overheating,+ exhausting out the relief ports are a few..
dara64
Yes I have the those problem's. I will be taking the drive off looks like tomorrow !! :eek:
Status
