where is my idle adjustment screw?
orrismic
I have a 1990 omc 3.0l. Anyone have a picture or diagram?<br /><br />Thanks.\\<br /><br />mike
hoot
Re: where is my idle adjustment screw?
no picture here. i have a mercarb 2bbl. the idle screw is not on the carb. it is on a bracket on the back side of the carb. it adjust the throttle position. watch your throttle linkage around the carb and see if you have the same thing.
orrismic
Is it the one with a spring on it around the back side
orrismic
One more thing, Should this only be adjusted on the water,in gear, and at opperating temp?
Reel Poor
Idle speed should be adjusted on the water, in neutral, and at operating temp, TO SPECS.
