Where is part number on Dist.?
llerrad
Merc, 302, 188, Ford V8, want to put ele. ing. on can't find the number on the distrubutor to tell which kit I will need. can someone guide me here.
llerrad
Re: Where is part number on Dist.?
bump
Reel Poor
If there are no numbers on it it's going to be hard without pics. There are four possibilities, Autolite, Prestolite, Mallory, and Mercruiser. The numbers would be on a plate or stamped into the housing.
alaska_av8r
Let us know where you find it I am looking to change over to electronic as well.....I THINK i have a prestolite since it is a screw on cap, others appear to be clip ons....
llerrad
Can't find the number any where even took the points plate off, will remove dis. and take it in to get the right ele. ign. kit.
alaska_av8r
does your distributor have the screw down cap, if so let me know what conversion kit you ended up with and how it works.........
I have tried 3 so far from Parts store and they get me the wrong one every time.....from wrong part in correct box....to something totally non related.
