Where is the gear the linkage on this model?
BlueBeast
1976 Johnson Seahorse model number 55EL76E, serial number E4473745
I have to drop the lower unit and I know I have to disconnect the linkage before or during the drop.
mark1961
Ensign
Re: Where is the gear the linkage on this model?
Isolate the battery, remove the shift rod pin (under the lower carb)......it may help to remove the starter and have the LU in reverse before attempting though.....then remove the LU bolts.....
1946Zephyr
Yep, you can find a good breakdown of your lower unit at marineengine.com
