WHERE is the main fuse on a 1993 Johnson 200 hp oceanrunner outboard ?
boatlover2020
I am looking for the location of a main fuse on the motor, this motor is a Johnson 200 hp Oceanrunner 1993 V6
I was working on changing the wiring in the center console and noticed the housing to the binnacle control was cracked. I removed the one screw out of 4 that was actually holding it in place and lifted to inspect the ignition key wiring, after putting the cover back in place everything went dead. I am thinking something touched and blew the main fuse. This is my first Johnson Engine so i am clueless. Any help would be greatly appreciated.
I have ordered a new binnacle control with tilt trim and ignition, as well as the main harness adapter wiring.
On my '98 Oceanrunner, it is located near the starter solenoid. The battery side of the starter solenoid serves as a connection point for several wires. One of those is the main fuse wire (red). It travels a few inches to the inline fuse, where the wire turns purple/red. There is a spare fuse located at the inline fuse site. You should be able to trace it.
