rasnattydred
Thread starter- Joined
- May 20, 2009
- 52
Can't find where my Mercruiser 4.3l V6 (1997) transmission fluid is located, I would assume this engine has transmission fluid.
That would be gear lube in your out drive.
what you would normally refer to as a transmission in a car is all contained as the gears in your drive. so yes. just make sure you use the proper lube for your application as it does not take transmission fluid.
You could have a transmission if you have a straight inboard. Mercruiser makes both. Do you have an prop and rudder outside the boat or an outdrive attached to the transom.
