mvanmansum
- Joined
- Sep 5, 2005
- 4
I've just purchased a 1978 Apollo 17' boat w/ supposedly a 350 chev. It's driven w/ a 260 Merc w/ power trim and has been outfitted w/ a Land and Sea torque shift prop, hydraulic trim tabs and thru hull exhaust w/ chrome droop snoots (not a quite boat when on plane). <br />1- Everything works, 'cept the speedo quit my first day- plastic nub that holds tubing on pick up/sensor broke off, but I'm looking for manuals on the engine, trim units (tabs and drive), merc drive, wiring, etc. How should I go about obtaining those? <br />2- I'm considering running the exhaust back thru the drive to quite things down while on plane - I see a rubber cover over what seems to be the exhaust entry into the drive unit. It looks as thought I'd have to combine the rubber manifold exhaust tubes then route into the drive. Is this correct and could there be a way to put a captains choice type of setup on there? <br /><br />Thank you<br />new boater
