where should the motor sit on the boat
I'm trying to figure something out, With the motor in the lowest position where should the fin be in respect to the bottom of the transom. <br />even, an inch above, or an inch below?
WillyBWright
Re: where should the motor sit on the boat
Welcome to iboats. :) <br /><br />Even for average, above for speed, below for bite.
JB
Outboard Non-repair topic.
Chief101
I give up Steve, what kind of boat do you have? Pontoon or sail? ;)
waterinthefuel
I typically put my outboards in the back, usually mounted to the transom.
Wiggy
I've got a long shaft on a shoft shaft boat. What are you downsides/advantages of this set-up.<br /><br />Is it damaging the boat/motor at all?<br /><br />I've heard that the motor's anti-cavitation plate should be parallel with the bottom of the boat?
waterinthefuel
It's not hurting anything but your top speed. <br /><br />I've heard the same thing about the cav plate.
