Where the da antisyphon
acupajoe
Have a mercruiser 120 86 and not even sure I have a antisyphon in fuel system. Do I need one and where the heck is it.
Thanks again.
Joe
Bt Doctur
Re: Where the da antisyphon
It`s the very first fitting you see at the tank.It`s function is to prevent gas from "free flowing" out of the tank if a line ruptures.Just a spring and ball setup.
HT32BSX115
Technically you only need one if the following is not met.
183.568 - Anti-siphon protection
Each fuel line from the fuel tank to the fuel inlet connection on the carburetor must:
(a) Be above the level of the tank top
Even if every part of the fuel system is all above the tank it's still not a bad idea to have one installed. They're cheap and you can get one form both Boaters World and West Marine.
Regards,
Rick
acupajoe
Thanks for the info...I do have below deck tank so it is lower, but anyway will just pick up one.
