vrodrig
- Joined
- Sep 16, 2011
- 90
Hello folks, I finally recived my Seloc repair manual I begain reading the lower unit specs for the gear case shimming. It explains the procecure for setting up backlash and shaft endplay (Drive shaft and prop shaft). The only problem with this book is that it is very vague on some of these proceduers and there are limited pictures to show tools and parts being assembled.
For example, it mentions a pinon gear shim but no where in the text it tell you where it's positioned on the shaft, the picture diagrams don't show it either! The only shim that is on the drive shaft is the one at the top part of the shaft on the upper shaft bearing and the picture diagram says its a SHIM not a PINION GEAR SHIM. Uhgg!!! Can any one tell me whats up with that!
I would like to set this thing up the according to specs but it is frustrating having to guess what it is I need to do. I replaced all the bearings and prop shaft hub so it need to be set up right. Can anyone help!
