Where to buy badger hair or china bristle.
thrillhouse700
So this entire morning I have been trying to find one of these brushes for when we paint the boat, as it is what the instructions call for. I have called home depot, lowes, michaels, aaron bros, a mom and pop art store............... Where do I buy this?
Bob_VT
Re: Where to buy badger hair or china bristle.
A good paint store...... are you going to tip and roll? Do not het hung up on the exact brush but do get a quality brush.
thrillhouse700
Hmmm so what have you guys used then? I got those HD foam rollers, but am really stumped on the type of brush. Supposedly badger hair and white china bristle is for polyurethane and very fine and provides a glass like finish.
HVAC Cruiser
Hey Thrillhouse, Home Depot carrys white china bristle brushes, listen to Bob_VT and get a good quality one Purity makes a decent one about $12 for 3" wide
thrillhouse700
ok, we bought one of those and messed it up with that primer stuff haha. I just wasn't sure if that was fine enough because i have never seen or felt a badgers hair.
HVAC Cruiser
I was a GC back in the 90's and don't think I have ever used a badgers hair brush never seen one so I could not tell you. What I can say is that sometimes even though it might look the same you can get a better quality at a sherwin williams or benny more store than HD. HD alot of times gets a cheeper quality to be able to under-sell their competitors. thats one reason I refuse to buy power tools from there. There is a difference
TojosMojo
This is where I'm buying all my painting supplies including my Interlux Perfection, I know you may want to buy it local but I thought I would post this anyway...
the brush is here and you choose the size at the top right of page with a drop down menu...
http://www.jamestowndistributors.com/userportal/show_product.do?pid=2113&familyName=Badger+Hair+Brushes
They also have this paint kit on sale for $33.99
http://www.jamestowndistributors.com/userportal/show_product.do?pid=4276&familyName=JD+Topside+Priming+and+Finish+Coat+Prep+Kit
drewpster
You want whatever tipping brush you choose to have fine random bristles. You want it to hold up to strong paint and cleaning solvents. You want it to have a relatively soft feel. The stiffer the bristle the deeper the impressions it will make. You want it to be generally well made. If you look closely at a cheap brush versus a more expensive one you will notice the differences. One of the most important is the better brush will not lose bristles even after cleaning in strong solvents. Better finishing brushes have round handles so that they can be spun clean. Take a look at the cut of the bristles on the end of the brush. Better tipping brushes are made for that purpose. The bristles will taper to the tip rather then being a straight cut at their tips. China bristle brushes are made of Chinese boar fur. I misconception is that so-called badger brushes are more often china bristles that have been whipped so that the hairs split making the brush more fine. There are tons of options especially if you order online.
The point is, you want the thing to be soft, tapered, have a fine edge and easy to clean. More often than not you are going to pay a higher price for all those options. The most important, is that it does not contaminate the paint. Trust me, its a real pisser to find a stupid paint bristle dried in to the otherwise perfect paint job you did.:mad:
A good tipping brush can be found at Home Depot or Lowes. It may not have all the options I described. A good China bristle will do a good job and they run in the $15-$20 range. A better brush with a round handle, tapered natural bristles in the 3 to 6 inch width start at about $25-$50 range. You can get more expensive ones but then your overbuying.
Hope this helps,
drewp
BTW- a tipping brush should be for tipping only. you can buy a cheaper one for applying the paint. the tipping brush should always have a clean supply of solvent near by because you want to keep it clean as you go along.
thrillhouse700
Wow drep thats all great info, Thank you. I will hit a few stores monday and see what I can find.
drewpster
Thanks I am known for my ability to complicate any subject. :p
thrillhouse700
As stated before we are both extremely nervous to paint this thing.....
