Where to Buy?
kenawell1
I need all parts to convert 25c3 nissan to console steering,shift,and start? I cant find a store that carries all parts. drag link, cables, rc kit etc?
Anywhere? A dealer on here?
TOHATSU GURU
Re: Where to Buy?
Any one of a thousand dealers across the U.S. or either Paul or myself on here. Just keep in mind that the cost of those parts are going to be around $800.00, that's a lot to put into an old engine. You would be better off finding a used engine with all the stuff.
kenawell1
Re: Where to Buy?
I need src kit,drag link, and shift/throttle cables, steering cable . the control box ill buy used. what else cause i didnt think that made 800 but i could be wrong!
pvanv
Re: Where to Buy?
You didn't mention whether you are already electric start or not. If not, you will need the electric start kit. Some items you may need, depending on your current configuration are:
346849051M DRAG LINK ***'Y $70.96
353849040M SPACER, DRAG LINK STEERING $61.44
346849010M PLATE, TURN BUCKLE $36.02
3P0760000M ELECTRIC START KIT P TYPE $608.16
3A1838801M SRC KIT;9.9B-18C,25,30 $172.32
361838530M RC STOP CORD ASSY $65.66
345760230M GROMMET FOR STOP CORD $4.04
3B7Q843503 RC BOX, RC5C, AMB w/ elec start $386.13
Depending on distance, you will need the appropriate length Morse-style cables. For example, if 15-foot cables are needed, you would order (2) HC49J96-15FT, $42.59 each.
You will need to order the appropriate steering cable, in the proper length, for your specific helm.
Sea Rider
Re: Where to Buy?
Comfortness is costly, cheappy is to remain with arm throttle steering and pass that 25 horse to 30 HP :D
Happy Boating
kenawell1
Re: Where to Buy?
Its a 25c3 w elec start.
i plan on not buying the nissan control box, if i buy the drag link do i need that spacer and plate? Im unsure aboutstop cord ***. and grommet. I have to look at book again
TOHATSU GURU
Re: Where to Buy?
You don't need the el kit, plate or the spacer...Unless they have changed what is in the SRC kit again:)
