where to find 1 1/2' face spanner wrench
now151
does anyone know where to find a face spanner wrench to unscrew caps off of a trim cylinder pretty sure the size is 1 1/2 inch. any other ideas for removing these caps?
Angrywasp
Re: where to find 1 1/2' face spanner wrench
Maybe harbor freight or make one out of a large wrench (but that would take some time). If you have a welder or know someone you might be able to weld one up.
Don S
What kind of trim cylinders?
Todd157k
Harbor Freight doesn't carry them. I tried. However Sears has an adjustable one. I ended up welding up my own from a spanner used on angle grinders.
arks
I use an adjustable pin spanner:
'For use with Groco strainers and deck plates with holes up to 7" apart. Cast bronze with 1/4" dia. stainless steel pins on one side and 5/16" pins on the other. Made in USA. Model SW2531.'
JoLin
Google 'face spanner wrench'. They're readily available. I bought an Armstrong wrench off Amazon a few years ago when I rebuilt the trim unit on a 175 Johnson. I did have to use a grinder chucked in a drill to modify the tool a bit for my needs. That was pretty easy to do, and it worked.
Might be easier to take the cylinder to a machine shop and have them remove and reinstall the cap(s).
My .02
