Where to find this fitting for closed cooling exhaust?
CLi87
I'm trying to find this brass connector that connects from my exhaust manifold to the closed cooling hose on my Mercruiser 5.7. It's a 1" OD barb type fitting with a 45 degree bend to a 1" NPT, I've tried looking everywhere and can't find it, anyone know where I could find one?
Bobpeeks
I think the threaded part is 3/4" NPT (NPT threaded pipe is measured by inside diameter). Not sure that will help you find the part.
CLi87
O, ok, so 3/4" NPT male to 1" OD or should I be measuring that other side using ID as well? the ID looks to be 7/8"
Fun Times
Though not your exact designed match as yours may be an aftermarket CC kit, the 2 following are what Mercruiser seemed to have used both older and newer year models with their kits.
An older merc part number was 22-92499T,
While the newer part number for newer engines seems to be 22-865159 Fitting 45°,
Bobpeeks
Hoses would also be measured by their inner diameter, so the 1" OD of the fitting goes into a 1" ID hose.
Can make it with
And
Or shop for groco fittings. https://powerboatsupply.com/boat-su...gngE3SPOepymf1zUCIeS_-JY34vuYJphoCalsQAvD_BwE
