Where to get a manual?
Dar73
I have an old mariner 30HP 2 stroke...where do you guys buy your manuals? Online pdfs available?
Fun Times
Post up the engine serial number as it may help locate a manual or OEM part number to buy one, etc..
Fun Times
Hi... serial no is 689 - 8 - 232070
Serial number 232070 comes up as an 1991 MARINER SANSHIN IN 30-H.P. (M)
Model Number 7030201YW
Your -8- is actually an "S" which ='s Short Shaft.
90-84681--1 / 2-1091 Covers engines - 20C (6A9)/25C (695)/W25 (695) /30A (689)/ W30 (689) With Thru Prop Exhaust.
All Serial Numbers:
30 M689-231306 - 689-2327751991
Texasmark
I work the 3-4 cyl 2 stroke Merc arena. My last 2 engines were 2002 models. OEM manual I had with the 3 cyl was for engines in this category and the manual starts with the 1994 engines and goes on out to the end of production in 2005 I assume...since I am interested in 2002 year models.
So I donated that rig, the one in my Avatar (and manual) to the local fire/rescue dept thinking I was out of boating. Boat was perfect for their kind of work. 5 years later I'm back into boating with a 4 cyl of the same yearmodel. In looking for a manual I went to ebay and found the same manual but it was updated in 2015. There are some subtle differences, some things are explained more clearly. One thing I noticed the gapped plug was an option in the original manuals is no longer listed. Too bad as I liked to run the gappers in the 3 cyl and I run them in the current 4, Iridiums.....NGK BPR6HIX, NGK stock # 4085 gapped out to 0.040 like the original copper tipped, gapped plugs.
Dar73
All Serial Numbers:
Thanks Fun Times...much appreciated.
