Where to get a new trim switch?
roscoe
Re: Where to get a new trim switch?
Are u sure its the switch on the controls, and not a relay on the motor wiring harness?
Remove the motor cowl, locate the 2 relays, they look just like an automobile relay.
Unplug them and swap the 2 relays.
If it is a relay, the motor will now only trim up.
tschmidty
Or it's the trim limit sending unit on the outdrive.
CharlieZulu
Thanks for the advice, but I *think* it's the switch.
When I short out the UP terminals on the back of the switch, up she goes.
Good diagnosis?
Bob_VT
I would use a multimeter and test the switch before I replaced it. It is more common for the relays to fail or corrosion to build on the contacts.
Shorting the wires is okay but not the real test.
Test the circuits and make sure everything is clean before you spend the money.
CharlieZulu
Hmmmm.... OK, thanks.
I don't have a schematic in front of me, but my logic tells me that if it's a simple single-pole-double-throw (SPDT) rocker switch, and I short the UP to the +12V terminal right there on the back of the switch by laying a screwdriver right across those two terminals, and my motor goes up without hesitation, then it's something internal to the switch. By doing this I am basically sending +12V right to the UP relay, no?
insearch
You are correct. Th PO of my boat put an aftermarket rocker on the dash, I would love to have the one back that is on the throttle but they don't exist anymore
tschmidty
Looks like a pretty decent diagnosis to me. But how is it wired? Any chance the trim limit sender is wired into the switch itself? As in how many terminals are on the switch? Or is it all wired as one piece?
The real test would be disconnecting the switch and checking resistance with a multimeter. You may just have corrosion so it might be worthwhile to take it apart and clean it up.
CharlieZulu
Trim limit sender? :confused:
All I know is the trim switch has always worked properly, so something somewhere has gone u/s. Also, since the DOWN works OK, no matter where I stop the motor in terms of tilt position, nothing happens when I press UP anymore.
The switch only has 3 terminals on the back and 3 wires going off it. I am going on the assumption that one is +12V and the other two are UP and DOWN. Like I said, I took a guess and shorted two terminals together on the back of the switch, and up she goes.
There is considerable corrosion on the solder joints -- lots of green/gray oxidization, but I would say this is surface contamination, really. I did not have the opportunity to clean this up (ie restrip the wires and re-solder... this would have made them too short anyway)
It looks like the switch assembly might come with the 3 wires already soldered -- sort of a pigtail affair, so this is what I'm actually looking for.
