where to get epoxy compatible mat in 38" width?
whosmatt
hi,<br /><br />having a hard time finding this stuff... uscomposites has 50" width but that's too much for me. anybody know a good source?<br /><br />thanks<br /><br />matt
Boomyal
Re: where to get epoxy compatible mat in 38" width?
Step up Whosmat. It isn't going to cost that much to buy the 50". They are so much less expensive than everyone else. Probably be cheaper than someone with 38" anyway. Next size down would probably be 36" anyway.<br /><br />You can always cut off the 12" and lay it at one end or the other of your run.
whosmatt
it's not about the cost. 50" is just too big for my project. i guess i can cut it, but i figured somebody has to make a smaller size.<br /><br />matt
Ralph 123
Can't you use their biaxial? - that's the stuff West System recommends for use with their epoxy<br /><br />Here is the 38" stuff Contains double bias (17oz) stitched at 45degrees along with one layer of 3/4oz mat The following biaxial fabrics are compatible for use with polyester resins, epoxy resins and vinyl ester resin<br /><br /> http://www.uscomposites.com/specialty.html
whosmatt
yeah, that biaxial looks perfect. i didn't even check that stuff out. thanks<br /><br />matt
