Where to get replacement spark plug wires for 1976 evinrude 4hp??
Bknboat16
Need to replace damaged spark plug wires on 1976 evinrude 4hp . What are best type to replace with and where can i get them at a fair price. I cant find exact specs or any info on replacements.
your local dealer has rolls of spark plug wire in stock
Crosbyman
most motorbike, chainsaws snowmobile shops have it and can sell you a few feet (4) around $2 a foot . had indicated it must be metallic strand core .
automotive stuff is resistive and used to prevent RF noise in the A.M band but biker, snowmobiler etc... don't care
autoparts stores probably have some.
this is what I use but it was $35 a year or two ago !!!! now $78 ???? comes with boots :)
kbait
I used auto wires (resistive type) once way back when, before I knew better. Ran great for about 10 minutes😎. These magnetos require metal strand plug wires.
Not hard to find the correct wire at all.-----And you need to put the new wire into the coil before the coil is set in place.----And the coils must be set it the correct place for proper clearance with magnets.
Crosbyman
align coils on bases otherwise they will rub on the flywheel. your fingernail should not snag going up or down the face of the base and coil if aligned properly !!!
also critical is to tuck in the coil primary wires to the points away from the rotating cam
