Where to get signal for tach
yamatech43
Re: Where to get signal for tach
ok, yamaha uses grey for the tach signal, don't know what color g3 uses, just see what connects to the grey wire on yamaha side, this is the tach lead.... this kit will work...you connect it directly to engine lead, no need to use g3 wiring.
stylesabu
for that kinda money it should install itself. ther is a way to test harness for a wire with a variable pulse with engine running, i would start with grey on yamaha and yellow on suzuki. then there is also a setting on tach it self which has to do with number of poles on stator
99yam40
4 strokes used grey and 2 stokes used green
yamatech43
oops, sorry....grey would be the overheat....green it is.
T_Herrod
There is a green wire in a pull out harness that comes from the remote. It is hot when i crank the engine. Is this the signal wire??wiring.jpg
99yam40
yes it is
black is ground,
yellow is key on power for tach
green tach signal
T_Herrod
Thanks so very much !!!!!!!!
Now to buy a tach. Will just any tach from my local auto parts store work or do i need a marine tach?
doonda61
No a tach for a car will not work on your boat. Get a 7k tach - 7000 is for outboards and 6000 is for I/O - they are pretty easy to install, if I can do it .. anyone can.
yamatech43
You will want to set you MARINE tach's pole setting to 6 pole....there will be dip switches on the back and will probably come with some
simple instructions....this engine is a 6 pole, most Yama's are 12 pole.
