minuteman62-64
Thread starter- Joined
- Apr 12, 2011
- 1,350
Motor: 1982 Mariner 30A. Wasn't used for about a year. Ran OK when last used.
Started it up a week or so ago, in a barrel. Ran OK at idle and about 1200 rpm for maybe 10 minutes, with normal temperatures (based on my cylinder head sensor) and good flow from tell-tale. Then, running at idle, tell-tale flow petered out to just a dribble and motor over heated.
OK, I know this drill. Impeller over a year old, sitting for a long time, needs replacing. Installed new impeller and put motor thru its paces in barrel. All OK.
Thursday took it out to Mission Bay (San Diego) for a victory lap. Everything good to start. Then, on a long run (maybe 30 minutes) in the 5 mph zone, the head temperature started drifting up a bit. Still decent flow from tell-tale, both at idle and when I goosed the throttle a bit just to test it.
On the return leg, about half way back, overheat alarm went off and flow from tell-tale stopped. No kelp clogs so waited awhile and started up again. Tell-tale flow to start, then tapered off to nothing.
Limped back to the landing with help of tail wind and intermittent motor thrusts. Sat at the dock for about 15 minutes then it started up with modest tell-tale flow and ran enough to get on the trailer.
Back home, I pulled the lower unit expecting a messed up impeller. Nope, impeller was in great shape.
Where do I look for problem?. Seems to be a combination of intermittent pumping after warm up and low water flow in general.
