Re: Where to Mount a CDI/Rapir rect/reg
I never had a regulator (hopefully the mounting holes for it are there? do you think?). I always just had a 9 amp stator, which means I only needed a rectifier. Now because of overcharging issues with my new CDI/Rapair stator I bought their rect/reg # 194-5279. If I don't have the tapped holes where the regulator would be, what should I do?. Can I mount a peice of aluminum using the tapped holes for the rectifier. Then use some self-tapping screws to mount the CDI rect/reg onto the aluminum.<br /><br />Out of curiosity, where did you purchase the aluminum? Junk Yark?<br /><br />-thanks<br />andy
