sublauxation
Thread starter- Joined
- Oct 13, 2008
- 1,317
I'm redoing the entire layout of my boat and via some measuring errors it turns out there's no room for putting my fuel tank under the deck. The biggest downside is I now have to find a new place for my batteries.
I have a starting battery and a deep cycle. I had a battery die on the Mississippi River last year and it was a pain switching them out so I wanted to put them side by side so I can use a battery switch just in case this happens again. The problem is, because of the fuel tank fiasco there's no easy place to make that happen. I was hoping you guys could give some thoughts on my options. The boat is an 18 foot aluminum dual console.
1) My main concern is voltage drop. If I put both batteries in back I'll need 18 feet of cable from the deep cycle to my trolling motor. Is that too much?
2) I can put both batteries up by consoles the but I'd need new cables for the starting battery, the current cables are 8ft long, I'd probably need 12 ft total to put them here.
3) I can put the starting battery in back and the deep cycle up front but I'd need at least 12 feet of cable to attach the deep cycle to the selector switch in back.
Is there any problem with moving a battery up to the front? The deep cycle would fit like a glove right at the front of the bow. It's otherwise wasted space but I know it will be bounced around more up there.
