Re: Where to take my Force for ignition timing verification in Dallas?
OH Please don't take it to anyone! You can time it right in the driveway. Simply set the control handle to full forward. remove and ground all sparkplugs so the engine can not start, now, crank the engine over with a jumper or have a friend crank it while you aim a timing light at the flywheel. There is on line on the pointer above the carb and three grouped lines on the flywheel. If the light flashes and stops motion with the rightmost line centered on the pointer line, timing is correct at 28 degrees before top dead center. This is correct at cranking speed while running speed is 30 degrees BTDC. THe timing will automaticaly advance from 28 to 30 when the engine is running.
Simple, fast, saves money, AND you won't get a raft of s**t from someone who does not know these engines
