Wheres the grease fitting?? Lower gimbal pin swivel 1989 Alph 1 Gen 1 restoration
kramerpage
What am I missing here. There should be a bearing with upper and lower grease seal and grease port. Please advise thanksrps20150616gimbal_125703.jpg
Bt Doctur
Personally I would install the grease fittings, I have a video showing the install of the upper one.
kramerpage
I have a grease fitting on the top. The tolerance on the lower pin was good. Nice and tight but moved freely. To replace it you drive it out and epoxy a new slave in. I found this out by Stony loams post and googleing the part number.
stonyloam
Yeah, I think that was a time of transition, and the gimbal housings with the bushings probably did not have grease fittings. The upper pins, however, I think are the same ( upper hollow with a grease hole) and you could install a fitting.
