Which 150 HP Yam ?
Sea Rider
Summer is getting closer and temp is already warming up, my cousin needs to buy a new 150 HP OB for his current boat in replacement of an old 2 strokes 150 Evi. 2 nice alternatives to choose :
Yam 4 strokes 150 HP (Tech Specs)
Fuel Injected
4L/16 Valve/ SOHC/2650CC /228 KG
WOT Range : 4500-5500 RPM
Comsumption : 14.80 Gal/H at 5000 RPM
Price : $ 15,748.00
Yam 2 strokes 150 HP OB (Tech Specs)
3 Double Carbs
V6 / 2600 CC /185 KG
Consumption : 19.0 Gal/H at 5000 RPM
Price : $ 12,498.00
Weight Difference : 43 KG
Fuel Comsumption Difference : 4.2 Gal/H (29% more)
Yam is the most known and tech supported OB brand here for the last 50 years. Which model would you buy if asking price and fuel consumption is not an issue. Will be prop maximized along a correct OB/transom height match.
Happy Boating
flyingscott
I like the 2 strk because it is simple and basic and I am biased that way.. Easy to work on yourself but they are both wonderful motors.
82rude
All thing being equal and being a 2 stroke lover id have to go with the 4 poke.If the fuel diff is correct I believe in. awhile you,d make up the diff in price.Of course in awhile ii will change my mine then again in a couple more.Too bad Yamaha wouldn't add direct injection to their 2 strokes .Maybe they could liscence the tech from merc,toh,or evinrude?
mjf55
ezmobee
After owning both, I would not buy a new motor that didn't have fuel injection.
David Young
I have often said, "I will never own a car with a carburetor again". This is true. If I were ever in a position to own a fuel injected boat motor, I would jump on it in a second :)
Sea Rider
Yams has none 2 strokes EFI as Evinrude Etec, Tohatsu TLDI models, preffer traditional carbed models in all their 2 strokes OB range. If new OB will be usd on areas where 2 strokes are much preffered and is better tech supported than 4 strokes, seems will go that route. We're a 2 strokes lover country all the way...
Happy Boating
boobie
I'm still in the 2 stroke camp for being simple to work on and less moving parts.
bassman284
ez, that's me too. I bought my boat new in 2001 with a 60 Merc 4stroke EFI and the pure joy of KNOWING every time you turn that key the result will be the same is unbeatable. A lot of folks here tout the 2 strokes because they're "simple and easy to work on". I've had my motor for 15 years and it's never needed any work other than oil changes so I don't really care whether it's easy to work on or not. I guess the oil changes could be a drag.
