Re: which engine coupler 4.3?
Well, my coupler arrived and I trial fitted it to my flywheel (the holes match)then slid it on the outdrive input shaft and it won't turn, knowing that I will need to remove the outdrive before I install engine I attempted to remove the outdrive and it won't come off but a 1/4 inch with it shifted to forward gear. Im guesing that the 5 years this boat sat out in the weather with engine out and the gimbal bearing exposed has caused it to be seized in the housing. Here is where things might get ugly if I do this wrong. My plan is to soak the bearing as best I can with PB Blaster, let sit 24hrs, hook a come-a-long to the outdrive to exert some pressure (I don't have any one to pry on it while I get inside the bilge) from inside the boat use a air hammer with a tapered punch to rattle the shaft and bearing out...maybe. anybody with a better idea? I don't want to FUBAR my housing or drive.
