Which functions should still work with ignition off?
Jacalore
Key off, trim up/down and horn still work, is this normal, or has prevowner rewired ignition switch?
Bob_VT
Re: Which functions should still work with ignition off?
yes....Normal
NYBo
The only things that should be powered by the ignition switch are the instruments and possibly the instrument lights. Oh, and the ignition.
JoshOnt
Yes that is correct, I have only instruments, instrument lights, ignition and my extra speaks powered by the key
Jacalore
Okay, thanks guys!
I hafta ask, why the trim motor active? The horn, I guess, I can understand, but the up/down outdrive?
NYBo
The main reason is to not put too much current through the ignition switch- it's not designed for it, and if it burns out...
It's also handy to be able to raise and lower the drive without having to deal with the key.
Bob_VT
So you can adjust the outdrive to service it....... if room permits (if you have clearance) in the winter it is best stored down to keep the pressure off the cylinders and water drained.
Jacalore
Okay, makes sense. Glad my boat is "normal"...
