Which is better for salt water
graduc
Started looking for a deck boat or pontoon will be dry stored and have to tow it for one of two miles to put in water. I was told by a mechanic to stay away from pontoon as it would be costly over the years and difficult to tow looking around 18 to 22 ft and spending up to 16k for our first boat will be used near St.Pete beach area Fl. What are your thoughts
pontoons in the gulf are iffy, weather can get rough quickly
however there are plenty out there.
ahicks
I agree, you see the 'toons everywhere. They do pull like a parachute, but if you are only pulling it a mile or 2, who cares?
The point I want to add is that unless you get into the higher powered (expensive) tri-toons, you are lacking the ability to cover ground quickly (assuming conditions will allow that). We haunt the area just north of Tampa, and typically launch in one of several rivers that requires a few mile long trip to get out to the Gulf. A deck boat may be the better option for that reason. They can get up on plane and cruise easily at speeds that will be near the top end of even something like a tri-toon.
We sold our pontoon boat for that reason. We were tired of the long ride to get out into the Gulf, and of course the return trip. We ended up with a 22' deck boat, and now have some serious go somewhere when/if we want to. Still fine for putting around, plenty of room, and maybe a hair easier to launch/retrieve/tow.
Outboards are the way to go for sure!
graduc
We are looking at a 2008 bennington south wind 21ft with a 150 up Yamaha
thanks for your help
ahicks
Have a pro, somebody not associated with the seller, check it out for you. An 11 year old boat that's seen salt water frequently can have many surprises lurking that an untrained eye will miss completely.
Yamaha a good plan.....
