Which of these are my Tilt Switches
woody619
I need your help. My dad and I just got this boat. It's our first. We're trying to figure out our Tilt Switch, not sure if somethings wrong or maybe we don't know where it is. Here's some Pics from left to right. Could it be any of these? Or should I be looking for switches elsewhere.
It's a 26' Sea Ray, Inboard, 350 Chevy Engine w/ Pre Alpha Outdrive
Here's what we know
(From Left to Right)
Switch 7 is Windshield
Switch 8 is Cabin Bilge
Left White Switch is Trim Tab
Right White Switch is Trim Tab
Black Button Switches are unknown
joed
Re: Which of these are my Tilt Switches
Tilt switch should be a momentary one. That is it will return to off when you let it go. I don't see any that look like that type except the two white ones you have identified as trim tabs and the black buttons. It could be the black buttons but I don't know why there would be three. Two should be enough.
captk
the three black push buttoms are your trim and tilt. The top is trim, the top and middle pushed at the same time tilt. the bottom down.
woody619
Thanks! I kinda thought that. I can't get my tilt to lower or do anything actually. I'm taking this thing to a marine mechanic this week to get it figured out. It could be so many things I don't know about. Thanks for the help guys!
what kind of sea ray is that exact it looks great looking for another one my self
woody619
I think it's a 1979 Searay Weekender.
dingdongs
at rear in engine bay you should be able to see a pump.hunt for the green and blue wires on it.
blue wire (sky)up
green wire(grass) down
connect a + from the battery with a wire to either and should activate trim in either direction.if it moves could be a switch/solenoid/wiring prob.
report your findings with pic may help too if all is still connected up.
