Re: Which plugs do I use?
Radar..... Pertaining to the fuel mixture. There are pros and cons about that. I've encountered bulletins that state that one can use the 50/1 mixture is all of the OMC engines, excepting the older 1957 7.5hp models. But I've also encountered brochure that states that if the engine does not have "all" roller or "needle" type bearings, to stick to their original mixture.<br /><br />The engines that you have DO NOT have "all" roller or needle bearings, but rather incorporate babbit or bronze type (solid) bearings.<br /><br />Bottom line... I'd strongly suggest that you use the original mixture which is 24/1 (1 Qt of 50/1 oil to 6 gallons of gas) to avoid any possible lubrication problem. That extra pint of oil doesn't cost that much when compared to the cost of the engine.
