well here is the dilemma, I`m not good with using short wood/sheet metal screw into the fiber glass on the adjacent side of the motor well. There is a gap between this wall and the storage locker on the opposite side of this hull location. The gap is tapered and is tighter at the topI can`t get use bolt/washer/nut with that scenario. So I`m thinking to bond a piece of stock that has 2 studs in it for mounting the water fuel separator. the stock would be bonded to the hull with epoxy, or 5200. after it`s cured I could hang the WS to the studs...
I don`t have enough height to hang it on the transom itself...
any other ideas? fire away...
the blue tape is about where it needs to be.
OR:
I could just drill through both walls, keep the outer the correct size, use a hole saw to get access for the nuts and washers.
just thinking out loud...
