Which rifle scope?
MTboatguy
Re: Which rifle scope?
Although I have not owned that particular model, I have owned several of models of this brand over the years and have always found them to be well made and a very good value.
ezbtr
Thanks for the info - oh and I did get scope rings/kit with my Mini 14 :)
CharlieB
I found a very nice scope on ebay, tho the money saved I ended up spending on a different set of mounts to fit the small rail of my 22
3 x 9 w/ 56mm objective, nice bright sight!
GTS225
Personally, I'd go for the 12 power. Then crank it to 12 and watch your heartbeat when you bench rest it at the range. But I just like to have the big picture.
Roger
lckstckn2smknbrls
I have the 8 point scopes on both of my lever action rifles and the 4 simmons 22 mag 3x9x32 on my 22's.
mk4713
I agree 3x9 is all ya need. The leopolds are nice but the cheaper ones work just fine for 10-22....
halfmoa
Ensign
If you really, really want to teach him marksmanship get a scope that has the ability to be set at 10X or a number easily divisable by 10 (ie. 5 in a variable 4-8 kind of setup) with mil dots and target knobs. The reason for this is that you can use the dots in your scope to actually measure target distance and place an accurate shot with proper holdover that's measured using the mil dots. If you've learned (and you should) how wide your dots are (typically 1/4 mil with other measurements from center to center, center to edge, far edge to far edge) and you place a shot that is off a half inch (or half MOA) 100 yards you can use your mil dots to measure and correct the misplaced shot with precision. It's difficult to learn and master but it'll make your son a marksman, guaranteed. In the mean time you'll have a scope that he can use to practice general marksmanship, breath control, trigger discipline and learn to rely on bone structure to hone his skills.
brunolund
just another note, 10/22's are not known for thier accuracy. at all. unless you,ve put a new barrel and some other work into it, it's just not going to help. you're better off with a good bolt action 22, or if he's old enough, a cheap savage or remmy bolt centerfire would be better to teach marksmanship. just keep the caliber suited to his size so he doesn't develop a flinch.
